docs:blox:connect-switched-outputs [2024/08/06 13:39] admin |
docs:blox:connect-switched-outputs [2024/08/15 12:53] (current) admin |
| Line 1: | Line 1: | ||
| - | ===== 2.7 Switched Output ===== | + | ====== 2.7 Switched Output |
| The Switched Outputs are are used to switch the incoming power supply voltage out to a device. | The Switched Outputs are are used to switch the incoming power supply voltage out to a device. | ||
| Line 9: | Line 9: | ||
| * Suitable for inductive loads | * Suitable for inductive loads | ||
| - | ==== 2.7.1 Wiring ==== | + | ---- |
| + | ===== 2.7.1 Wiring | ||
| | **BLOX Terminal** | **Device** | | | **BLOX Terminal** | **Device** | | ||
| Line 16: | Line 18: | ||
| | **Switched Output Example: Motors / LEDs** | **Switched Output Example: Relays** | **Switched Output Example: IoT Relay / Solenoid** | | | **Switched Output Example: Motors / LEDs** | **Switched Output Example: Relays** | **Switched Output Example: IoT Relay / Solenoid** | | ||
| - | ==== 2.7.2 Configuration ==== | + | |
| - | === 2.7.2.1 grblHAL/ | + | |
| - | No additional grblHAL settings required | + | |
| - | Use the **M7/ | + | ---- |
