docs:blox:connect-switched-outputs [2024/08/05 13:47] admin |
docs:blox:connect-switched-outputs [2024/08/15 12:53] (current) admin |
| Line 1: | Line 1: | ||
| - | ===== 3.9 Switched Output ===== | + | ====== 2.7 Switched Output ====== |
| + | The Switched Outputs are are used to switch the incoming power supply voltage out to a device. | ||
| + | > Make sure any devices powered off the switch output have the correct voltage rating to match your DC power supply, and does not use more than 2A of current. | ||
| - | ==== 3.9.1 Electrical Specifications ==== | ||
| * Max Current: 2A | * Max Current: 2A | ||
| * Voltage: 12-30v (Same as Input voltage) | * Voltage: 12-30v (Same as Input voltage) | ||
| * Suitable for inductive loads | * Suitable for inductive loads | ||
| - | ==== 3.9.2 Purpose ==== | + | ---- |
| - | The Switched Outputs are are used to switch the incoming power supply voltage out to a device. It can be switched on/off or controlled with PWM (Pulse Width Modulation) | + | ===== 2.7.1 Wiring ===== |
| - | > Make sure any devices powered off the switch output have the correct voltage rating | + | | **BLOX Terminal** | **Device** | |
| + | | GND | Low side Switched leg | | ||
| + | | V+ | 12-30V (Connected | ||
| - | | Switched Output Example | Switched Output Example | Switched Output Example | | + | | **Switched Output Example: Motors / LEDs** |
