docs:blox:connect-rc-servo [2024/08/06 13:36] admin |
docs:blox:connect-rc-servo [2024/08/15 12:51] (current) admin |
| Line 1: | Line 1: | ||
| - | ===== 2.4 Connecting BLOX to RC Servo ===== | + | ====== 2.4 Connecting BLOX to RC Servo ====== |
| OpenBuilds BLOX provides support for using an RC servo to raise/lower a pen, in Pen Plotter type applications, | OpenBuilds BLOX provides support for using an RC servo to raise/lower a pen, in Pen Plotter type applications, | ||
| - | ==== 2.4.1 Wiring ==== | + | ===== 2.4.1 Wiring |
| | **BLOX Terminal** | **Device** | | | **BLOX Terminal** | **Device** | | ||
| Line 12: | Line 12: | ||
| - | ==== 2.4.2 Configuration ==== | + | |
| - | === 2.4.2.1 grblHAL / CONTROL === | + | |
| - | Make sure to set grblHAL settings (CONTROL > Grbl Settings Tab) | + | |
| - | For most standard RC Servos that have moves 180 degrees set | + | |
| - | * **$33=50** Spindle PWM frequency | + | |
| - | * **$34=2** Spindle off Value | + | |
| - | * **$35=2** Spindle min value | + | |
| - | * **$36=15** Spindle max value | + | |
