docs:blox:connect-rc-servo [2024/08/05 18:49] admin |
docs:blox:connect-rc-servo [2024/08/15 12:51] (current) admin |
| Line 1: | Line 1: | ||
| - | ===== 3.4 Connecting BLOX to RC Servo ===== | + | ====== 2.4 Connecting BLOX to RC Servo ====== |
| - | ==== Wiring | + | |
| OpenBuilds BLOX provides support for using an RC servo to raise/lower a pen, in Pen Plotter type applications, | OpenBuilds BLOX provides support for using an RC servo to raise/lower a pen, in Pen Plotter type applications, | ||
| - | {{: | + | ===== 2.4.1 Wiring ===== |
| + | | **BLOX Terminal** | **Device** | | ||
| + | | GND | GND | | ||
| + | | 5V | 5V IN | | ||
| + | | SIG | Servo Signal | | ||
| - | ==== Configuration ==== | + | {{: |
| - | === grblHAL / CONTROL === | + | |
| - | Make sure to set grblHAL settings (CONTROL > Grbl Settings Tab | + | |
| - | For most standard RC Servos that have moves 180 degrees set | + | |
| - | * $33=50 | + | ---- |
| - | * $34=2 | + | |
| - | * $35=2 | + | |
| - | * $36=15 | + | |
