docs:blox:connect-rc-servo [2024/08/05 13:05] admin |
docs:blox:connect-rc-servo [2024/08/15 12:51] (current) admin |
| Line 1: | Line 1: | ||
| - | ===== 3.3.6 BlackBox X32 RC Servo ===== | + | ====== 2.4 Connecting BLOX to RC Servo ====== |
| - | ==== Wiring | + | |
| OpenBuilds BLOX provides support for using an RC servo to raise/lower a pen, in Pen Plotter type applications, | OpenBuilds BLOX provides support for using an RC servo to raise/lower a pen, in Pen Plotter type applications, | ||
| - | {{: | + | ===== 2.4.1 Wiring |
| - | ==== Configuration | + | |
| - | === grblHAL === | + | |
| - | Make sure to set $33=50 in grblHAL settings (CONTROL > Grbl Settings Tab > Scroll down to $33 Spindle PWM Frequency > Set the value to ' | + | |
| - | TIP: Set $33=50 (PWM frequency), $34=5, $35=5 and $36=10 to generate a " | + | |
| - | You may decrease $34 and $35 to output a shorter pulse than 1ms at min, and increase $36 to get a longer pulse than 2ms at max. | + | |
| - | For most standard RC Servos that have moves 180 degrees when $34 and $35 are set to 2 and $36 to 15 - resulting in a 0.4 - 3ms pulse witdh range. | + | |
| - | === Calibration | + | |
| - | OpenBuildsCONTROL includes a tool to calibrate the Pen Up / Pen Down positions of your Servo. | + | |
| - | Go to Wizards and Tools > Calibration > Calibrate Servo Pen Up / Down: | + | |
| - | === Pen Control Buttons === | + | |
| - | When $33 is set to 50hz, CONTROL will enable the Pen Up / Pen Down Buttons you can use to test you servo, check Pen Down positions to ensure your pen is touching the writing surface, etc | + | |
| + | | **BLOX Terminal** | **Device** | | ||
| + | | GND | GND | | ||
| + | | 5V | 5V IN | | ||
| + | | SIG | Servo Signal | | ||
