docs:blox:connect-psu [2024/08/05 17:22] admin |
docs:blox:connect-psu [2024/08/15 12:51] (current) admin |
| Line 1: | Line 1: | ||
| - | ===== 3.1 Connecting BLOX to Power Supply ===== | + | ====== 2.1 Connecting BLOX to Power Supply |
| Line 8: | Line 8: | ||
| | **Connecting a power supply via the barrel jack** | **Wiring to a power supply via the screw terminals** | | | **Connecting a power supply via the barrel jack** | **Wiring to a power supply via the screw terminals** | | ||
| - | | You can connect a power supply via the Barrel jack: 5.5x2.5mm Connector, Center-Positive. 12-30V. | Alternatively, | + | | You can connect a power supply via the Barrel jack: 5.5x2.5mm Connector, Center-Positive. 12-30V. | Alternatively, |
| + | | | NB: Set the 115/230v Switch | | ||
| - | NB: Set the 115/230v Switch: Before connecting your power supply to mains power, it is critical that you check and set the 115v/230v Switch on the right-side of the PSU: | ||
| - | Look out for the bright yellow sticker on the top, to help you locate the switch: | ||
