docs:blox:connect-psu [2024/08/05 15:15] 127.0.0.1 external edit |
docs:blox:connect-psu [2024/08/15 12:51] (current) admin |
| Line 1: | Line 1: | ||
| - | ===== 3.1 Connecting BLOX to Power Supply ===== | + | ====== 2.1 Connecting BLOX to Power Supply |
| Line 6: | Line 6: | ||
| - | ==== Connecting a power supply via the barrel jack ==== | ||
| - | You can connect a power supply via the Barrel jack: 5.5x2.5mm Connector, Center-Positive. 12-30V. | + | | **Connecting a power supply via the barrel jack** | **Wiring to a power supply via the screw terminals** | |
| + | | You can connect a power supply via the Barrel jack: 5.5x2.5mm Connector, Center-Positive. 12-30V. | ||
| + | | | NB: Set the 115/230v Switch | | ||
| - | ==== Wiring to a power supply via the screw terminals ==== | ||
| - | Alternatively, | + | ---- |
| - | NB: Set the 115/230v Switch: Before connecting your power supply to mains power, it is critical that you check and set the 115v/230v Switch on the right-side of the PSU: | ||
| - | Look out for the bright yellow sticker on the top, to help you locate the switch: | ||
