docs:blox:connect-limit-switches [2024/08/06 12:10] admin |
docs:blox:connect-limit-switches [2024/08/15 12:52] (current) admin |
| Line 1: | Line 1: | ||
| - | ===== 3.6 Connecting BLOX to Switches ===== | + | ====== 2.6 Connecting BLOX to Switches |
| Line 7: | Line 7: | ||
| These inputs are also the best choice for all other kinds of switches like toggle, push, lever or relay switches. | These inputs are also the best choice for all other kinds of switches like toggle, push, lever or relay switches. | ||
| - | > TIP: Set the Limit Switch voltage as required: | + | ---- |
| + | ===== 2.6.1 Switch | ||
| + | | **BLOX Terminal** | **Device** | | ||
| + | | GND | GND | | ||
| + | | V+ | Power Input (Optional, for powered sensors, filtering or LEDs) | | ||
| + | | SIG | NO/NC terminal of switch | | ||
| | **Xtension Limit Switches** | **Lever Micro Switches** | **Inductive Sensors** | **Others** | | | **Xtension Limit Switches** | **Lever Micro Switches** | **Inductive Sensors** | **Others** | | ||
| - | penBuilds | + | ===== 2.6.2 Switch Voltage ===== |
| + | OpenBuilds | ||
| > These jumpers are located underneath the top cover of the BLOX, remove a screw on one of the sides to remove the top cover | > These jumpers are located underneath the top cover of the BLOX, remove a screw on one of the sides to remove the top cover | ||
| Line 19: | Line 31: | ||
| Limit 1's and Limit 2's voltages can each be set to individually as needed: | Limit 1's and Limit 2's voltages can each be set to individually as needed: | ||
| Set the jumper according to the required voltage for the sensor / limit switches attached: | Set the jumper according to the required voltage for the sensor / limit switches attached: | ||
| Line 25: | Line 37: | ||
| ==== 5V Endstops (Default) ==== | ==== 5V Endstops (Default) ==== | ||
| ==== 12-30V Endstops (Same as input supply voltage) ==== | ==== 12-30V Endstops (Same as input supply voltage) ==== | ||
