docs:blox:buttons [2024/08/08 17:37] admin |
docs:blox:buttons [2024/08/15 12:53] (current) admin |
| Line 1: | Line 1: | ||
| - | ===== 3.1 Onboard Buttons ===== | + | ====== 3.1 Onboard Buttons |
| Blox has two onboard buttons to control its operation | Blox has two onboard buttons to control its operation | ||
| Line 10: | Line 10: | ||
| | **Mode** | Can be used to place the device into Bootloader mode, and also available inside the firmware as an accessible input button | | | **Mode** | Can be used to place the device into Bootloader mode, and also available inside the firmware as an accessible input button | | ||
| - | ==== 3.3.1 Configuration ==== | + | ---- |
| - | === 3.3.1.1 grblHAL/ | + | |
| - | * Reset reboots the device | + | |
| - | * Mode Button is not assigned | + | |
| - | * Holding MODE while pressing Reset enters Bootloader Mode | + | |
| - | === 3.3.1.2 LogiBLOX === | + | |
| - | * Reset Button reboots the device | + | |
| - | * Mode Button is available as a Digital Sensor | + | |
