docs:blox:buttons [2024/08/05 18:39] admin |
docs:blox:buttons [2024/08/15 12:53] (current) admin |
| Line 1: | Line 1: | ||
| - | ===== 4.1 Onboard Buttons ===== | + | ====== 3.1 Onboard Buttons |
| Blox has two onboard buttons to control its operation | Blox has two onboard buttons to control its operation | ||
| Line 9: | Line 9: | ||
| | **Reset** | Restarts the device | | | **Reset** | Restarts the device | | ||
| | **Mode** | Can be used to place the device into Bootloader mode, and also available inside the firmware as an accessible input button | | | **Mode** | Can be used to place the device into Bootloader mode, and also available inside the firmware as an accessible input button | | ||
