docs:blox:blox-wifi-messages [2024/08/28 17:17] admin |
docs:blox:blox-wifi-messages [2024/08/28 17:26] (current) admin |
| Line 24: | Line 24: | ||
| This setup provides a flexible and extensible way to manage inter-device communication and integration with other networked applications. | This setup provides a flexible and extensible way to manage inter-device communication and integration with other networked applications. | ||
| - | **Technical Details**: | ||
| - | BLOX sends and receives on port 49160 | ||
| ===== 6.6.3.2 Sending Messages ===== | ===== 6.6.3.2 Sending Messages ===== | ||
| Line 36: | Line 32: | ||
| ^Sending an analog sensor value^Sending a digital sensor value| | ^Sending an analog sensor value^Sending a digital sensor value| | ||
| Line 47: | Line 43: | ||
| ^Receiving analog sensor value^Receiving digital sensor value| | ^Receiving analog sensor value^Receiving digital sensor value| | ||
| - | |{{:docs: | + | |{{docs: |
| - | ===== 6.6.3.4 Monitoring messages ===== | + | ===== 6.6.3.4 Monitoring |
| + | You can see broadcast messages in the BLOX Serial/USB logs | ||
| Messages are broadcast unencrypted for simplicity. This also allows you to very easily monitor and troubleshoot issues, as well as integrate it into other scripts and programs | Messages are broadcast unencrypted for simplicity. This also allows you to very easily monitor and troubleshoot issues, as well as integrate it into other scripts and programs | ||
| - | For example you can listen out for messages from a computer to help you troubleshoot | + | For example you can listen out for messages / send messages from a computer to help you troubleshoot |
| - | You can also see broadcast messages in the BLOX Serial/USB logs | ||
| - | {{docs: | ||
| Line 67: | Line 63: | ||
| ===== 6.6.3.4 3rd party integration ===== | ===== 6.6.3.4 3rd party integration ===== | ||
| - | You can use your own code to send and receive UDP messages in the formag | + | You can use your own code to send and receive UDP messages in the format |
| + | **Technical Details**: | ||
| + | BLOX sends and receives on port 49160 | ||
| + | Data is sent as a simple string in the format idtag=value. For analog sensors the value is the numeric value. For digital sensors its 0/1 respectively. Quite simple and easy | ||
| For example: Sending via a custom nodejs program | For example: Sending via a custom nodejs program | ||
| Line 83: | Line 85: | ||
| // The message to send | // The message to send | ||
| - | const message = Buffer.from(' | + | const message = Buffer.from(' |
| // The target port and broadcast address | // The target port and broadcast address | ||
| Line 121: | Line 123: | ||
| const value = keyValue[1]; | const value = keyValue[1]; | ||
| console.log(`Received analog_read_1_blox_2 value: ${value}`); | console.log(`Received analog_read_1_blox_2 value: ${value}`); | ||
| + | // do something with the value | ||
| Line 134: | Line 137: | ||
