docs:blackbox-x32:connect-xtension-limit [2022/08/24 17:59] admin |
docs:blackbox-x32:connect-xtension-limit [2024/08/05 15:15] (current) |
| Line 2: | Line 2: | ||
| ===== 3.4.1 Connecting BlackBox X32 to Limit Switches ===== | ===== 3.4.1 Connecting BlackBox X32 to Limit Switches ===== | ||
| - | Tip: Our Limit switches uses Normally-Open switch wiring, please ensure that you have '' | + | Tip: Our Limit switches uses Normally-Open switch wiring, please ensure that you have '' |
| Use a 3-core cable to wire up our Xtension Limit switches. | Use a 3-core cable to wire up our Xtension Limit switches. | ||
