docs:blackbox-x32:connect-vfd [2022/12/30 06:05] admin [3.3.5 BlackBox X32 0-10v Analog Output] |
docs:blackbox-x32:connect-vfd [2025/04/30 13:53] (current) admin |
| Line 1: | Line 1: | ||
| ===== 3.3.5 BlackBox X32 0-10v Analog Output ===== | ===== 3.3.5 BlackBox X32 0-10v Analog Output ===== | ||
| OpenBuilds BlackBox includes a 0-10v Analog Signal Voltage output that can be used to control spindles/ | OpenBuilds BlackBox includes a 0-10v Analog Signal Voltage output that can be used to control spindles/ | ||
| Line 6: | Line 5: | ||
| **NB Note** this is a low level logic Signal voltage, it should not be used to drive anything directly. This signal should be connected to an external drive system, for example a VFD or a DC Spindle Controller. If you need help, head over to our Forums to ask about specific devices and how to connect them | **NB Note** this is a low level logic Signal voltage, it should not be used to drive anything directly. This signal should be connected to an external drive system, for example a VFD or a DC Spindle Controller. If you need help, head over to our Forums to ask about specific devices and how to connect them | ||
| - | | + | * To use the signal, connect between the GND and 0-10v pins on the 0-10v plug as shown. |
| * To Activate the signal, send an M3 Sxxx where X=0-1000 (1000 = default Grbl configuration, | * To Activate the signal, send an M3 Sxxx where X=0-1000 (1000 = default Grbl configuration, | ||
| - | * If you want to use this feature to control Spindle RPM (on supported spindles), please read https:// | + | * If you want to use this feature to control Spindle RPM (on supported spindles), please read [[https:// |
| ==== Calibrate output voltage ==== | ==== Calibrate output voltage ==== | ||
| Line 20: | Line 19: | ||
| This will ensure that command Spindle RPM is as close to the actual as possible | This will ensure that command Spindle RPM is as close to the actual as possible | ||
| + | ==== Generic VFD wiring instructions: | ||
| + | This example uses RELAY1 as the Tool Enable, RELAY2 as FWD/REV and the 0-10V Output as speed CONTROL to control the VFD's activation, direction and speed respectively. | ||
| + | Every VFD brand labels their inputs slightly differently, | ||
| ==== Checkout our Forums for more information: | ==== Checkout our Forums for more information: | ||
| Line 27: | Line 33: | ||
| The following are community-provided writeups for wiring popular VFDs to BlackBox | The following are community-provided writeups for wiring popular VFDs to BlackBox | ||
| - | ^ ^ VFD ^ Link ^ | + | ^ |
