docs:blackbox-x32:connect-micro-limit [2022/08/24 18:02] admin |
docs:blackbox-x32:connect-micro-limit [2024/08/05 15:15] (current) |
| Line 5: | Line 5: | ||
| + | > Make sure to set $5=7 to use Normally Open switches with grblHAL on the BlackBox X32 | ||
| If you need a more EMI proof solution, consider upgrading to [[https:// | If you need a more EMI proof solution, consider upgrading to [[https:// | ||
