| Next revision | Previous revision | ||
docs:blackbox-x32:connect-3-wire-laser [2022/08/19 17:41] 127.0.0.1 external edit |
docs:blackbox-x32:connect-3-wire-laser [2024/08/05 15:15] (current) |
| Line 1: | Line 1: | ||
| ===== 3.3.2 Connecting BlackBox X32 to a 12v Laser Module ===== | ===== 3.3.2 Connecting BlackBox X32 to a 12v Laser Module ===== | ||
| - | If you would like to use both a Laser, and the IoT relay, See: [[docs: | ||
