Linear Actuators | Drive System | Accuracy | Available Sizes | Travel | Accuracy Positioning | Max Force | Max Speed |
V-Slot® Mini V Actuator
| Belt Driven GT2-2M Timing Belts | 0.003“ ~0.007” (0.10mm ~0.20mm) | 500mm, 1000mm, 1500mm | 15“, 35”, 54“ (380, 880, 1380mm) | 0.260mm | 2.5lb (11N) | ~10,000mm/min |
V-Slot® NEMA 17 Belt Actuator
| Belt Driven GT2-2M Timing Belts | 0.003” ~0.007“ (0.10mm ~0.20mm) | 250mm, 500mm, 1000mm, 1500mm | 7”, 14“, 33”, 47“ (170, 345, 845, 1190mm) | 0.260mm | 2.5lb (11N) | ~10,000mm/min |
V-Slot® NEMA 23 Belt Actuator
| Belt Driven 3GT-2M Timing Belts | 0.003” ~0.007“ (0.10mm ~0.20mm) | 250mm, 500mm, 1000mm, 1500mm | 7”, 14“, 33”, 47“ (170, 345, 845, 1190mm) | 0.563mm | 7.5lb (33N) | ~12,000mm/min |
Belt and Pinion NEMA 17 Actuator
| Belt Driven GT2-2M Timing Belts | 0.003” ~0.007“ (0.10mm ~0.20mm) | 500mm, 1000mm, 1500mm | 16”, 32“, 48” (410, 820, 1230mm) | 0.663mm | 2.5lb (11N) | ~8,000mm/min |
Belt and Pinion NEMA 23 Actuator
| Belt Driven 3GT-2M Timing Belts | 0.003“ ~0.007” (0.10mm ~0.20mm) | 500mm, 1000mm, 1500mm | 13“, 33”, 52“ (340, 840, 1340mm) | 0.311mm | 7.5lb (33N) | ~10,000mm/min |
V-Slot® NEMA 17 Lead Screw Actuator
| Lead Screw Driven | 0.001” ~0.003“ (0.05mm ~0.10mm) | 250mm, 500mm, 1000mm | 6”, 16“, 35” (150, 400, 900mm) | 0.075mm | 13.5lb (60N) | ~8,000mm/min |
V-Slot® NEMA 23 Lead Screw Actuator
| Lead Screw Driven | 0.001“ ~0.003” (0.05mm ~0.10mm) | 250mm, 500mm, 1000mm | 6“, 16”, 35“ (150, 400, 900mm) | 0.091mm | 26lb (115N) | ~8,000mm/min |
C-Beam Actuator
| Lead Screw Driven | 0.001” ~0.003“ (0.05mm ~0.10mm) | 250mm, 500mm, 1000mm | 6”, 16“, 35” (150, 400, 900mm) | 0.091mm | 26lb (115N) | ~8,000mm/min |
C-Beam XLarge Actuator
| Lead Screw Driven | 0.001“ ~0.003” (0.05mm ~0.10mm) | 250mm, 500mm, 1000mm | 4.5“, 14”, 35“ (115, 365, 885mm) | 0.091mm | 26lb (115N) | ~8,000mm/min |
C-Beam Double Wide Actuator
| Lead Screw Driven | 0.001” ~0.003“ (0.05mm ~0.10mm) | 250mm, 500mm, 1000mm | 3”, 13“, 32” (80, 330, 830mm) | 0.091mm | 26lb (115N) | ~8,000mm/min |
C-Beam XLarge X/Y Table
C-Beam Tension XLarge Actuator
| Lead Screw Driven | 0.001” ~0.003“ (0.05mm ~0.10mm) | 1500mm | 53.75” (1365mm) | 0.091mm | 26lb (115N) | ~8,000mm/min |
