OpenBuilds BLOX can be used with https://esphome.io/ and https://www.home-assistant.io/ as a Home Automation controller
Here's a basic example configuration YAML file for a BLOX under ESPHome, that you can use as a baseline configuration to build from
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
# Enable Home Assistant API: Use your own API KEY
api:
encryption:
key: "gb7rLDFCs79aFDLm2xhphwcm3ViVhnxnJkMtqF7yGoQ="
esphome:
name: blox-sample-config # Please change
friendly_name: BLOX Example # Please change
# Set DAC output levels on boot
on_boot:
priority: -10 # Lower priority ensures that outputs are set after ESPHome is fully initialized
then:
- output.set_level:
level: 0.3 # Set Stepper 1's default Current to 30%
- output.set_level:
level: 0.3 # Set Stepper 2's default Current to 30%
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_password
# Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: "Blox Example Fallback Hotspot"
password: "zTRqU4qZtwkd" # Please change
captive_portal: # Enable Captive Portal on fallback hotspot
ota:
password: "b99d5b4df91e72f2bff548ca73c57010" # Use your own
logger: # Enable Logs
web_server: # Show local web interface
port: 80
spi:
mosi_pin: 35
clk_pin: 36
miso_pin: 37
i2c:
sda: 3
scl: 4
scan: true
light: # RGB LEDs
- platform: neopixelbus
type: GRB
variant: WS2811
pin: 48
num_leds: 2 # Update count if you add external LEDs
number:
- platform: template
name: "Stepper Motor 1"
min_value: 0
max_value: 10000 # Set Max Travel Steps
step: 1
set_action:
then:
- stepper.set_target:
target: !lambda 'return x;'
name: "Stepper Motor 2"
min_value: 0
step: 1
set_action:
then:
min_value: -100
initial_value: 0
max_value: 100
step: 1
optimistic: true
set_action:
then:
- servo.write:
level: !lambda 'return x / 100.0;'
name: "Current: Stepper Motor 1"
min_value: 0
max_value: 3200
step: 1
set_action:
then:
- lambda: |-
float millivolt = x / 5.0 / 0.22;
int dacValue = (int) (millivolt / 3300.0 * 4096);
id(stepper_current_1).set_level(dacValue / 4096.0);
name: "Current: Stepper Motor 2"
min_value: 0
max_value: 3200
step: 1
set_action:
then:
- lambda: |-
id(stepper_current_2).set_level(dacValue / 4096.0);
stepper:
- platform: a4988
step_pin: 9
dir_pin: 8
max_speed: 250 steps/s
sleep_pin: 10
acceleration: inf
deceleration: inf
- platform: a4988
step_pin: 13
dir_pin: 12
sleep_pin: 14
acceleration: inf
deceleration: inf
binary_sensor:
- platform: gpio
pin:
number: 39
inverted: true
name: "Input: Limit: X"
- platform: gpio
pin:
number: 40
inverted: true
name: "Input: Limit: Y"
- platform: gpio
pin:
number: 11
inverted: true
name: "Input: Fault: X"
- platform: gpio
pin:
number: 15
inverted: true
name: "Input: Fault: Y"
output:
- platform: ledc
pin: 47
frequency: 50Hz
- platform: mcp4725
address: 0x60
- platform: mcp4725
address: 0x61
switch:
- platform: gpio
pin: 41
name: "Output: Switched Output 1"
- platform: gpio
pin: 42
name: "Output: Switched Output 2"
servo:
- id: rc_servo
output: servo_output
transition_length: 2s
auto_detach_time: 0.1s
